Hi Everyone
I have just received my Polo back from my partner whilst she has maintained the car with servicing etc it is in need of a little TLC before I sadly sell it on
One of the things I noticed is there is a huge amount of play in the throttle pedal, insofar you can pull it up by about 30 degrees
is there a way of adjusting the throttle pedal?
its' a 2000 SE Auto 1.4, I think it's an electric throttle?
Many thanks
Throttle Pedal adjustment
- sandshoes09
- Drives: Polo GTI 6N2
Re: Throttle Pedal adjustment
These polos don’t have a throttle cable, it’s controlled electronically and has a throttle control sensor at the top of the accelerator pedal linked to the ECU to the throttle body. There is a bit of play on the pedal, I have a GTI which does lift towards you quite a bit.
- From Haynes manual.
- IMG_1841.jpeg (3.21 MiB) Viewed 350 times
