How to fix the 6N2 ABS Signal Outside Specifications Fault
Post Instructions on DIY modifications here - use all information with caution!
alexperkins
Site Admin
Drives: 91 Golf GTI, 01 TT 225, 67 Q7
Re: How to fix the 6N2 ABS Signal Outside Specifications Fault
Post by alexperkins » Thu Nov 07, 2019 11:56 am
Hi Vas
Could be damaged wiring in the ABS loom. Any faults showing now?
vas.bak
Post by vas.bak » Mon Nov 18, 2019 9:35 pm
Alex actually me mekanic was check the abs wiring loom also the wiring from and modul to the left sensor.
Have any idea what it happens,
Thank you very much for your answer also your very important help mate
vas.bak
Post by vas.bak » Mon Nov 18, 2019 9:36 pm
The wiring it's ok
vas.bak
Post by vas.bak » Tue Nov 19, 2019 1:43 pm
I connect vcds and the fault I read is left front sensor problem. We delete the fault but comes again.
2 brand new sensors we change but the problem stay.
alexperkins
Site Admin
Post by alexperkins » Wed Nov 20, 2019 7:52 am
I’d say you more than likely have an internal break in the ABS wiring that feeds that sensor so you won’t see it. I’d replace the loom that goes through the wing to rule it out
vas.bak
Post by vas.bak » Thu Nov 21, 2019 9:52 am
Alex thank you for your fast answering mate.
that is, you are so sure that it is not the ABS unit and it is wiring loom?
I ask because my mekanic was check ohmmeter the wiring loom that feed the sensor from the unit and it's OK.
You think Something other?
Thank you very much.
vas.bak
Post by vas.bak » Mon Dec 02, 2019 7:43 am
Alex good morning.
Please answer.
Thank you very much
alexperkins
Site Admin
Post by alexperkins » Mon Dec 02, 2019 8:04 am
I would pick up a replacement ABS module and see if the problem goes away. If you are confident the loom is ok, then you may have a faulty controller.
vas.bak
Post by vas.bak » Mon Dec 02, 2019 3:54 pm
Thank you very much mate.
Marko106
Drives: 6R 1.6
Post by Marko106 » Wed Apr 15, 2020 1:40 pm
What type of glue did you use for close the ecu after repair?
alexperkins
Site Admin
Post by alexperkins » Sun May 17, 2020 10:57 am
Non acetoxy curing silicone
Sump gasket sealant for example or similar
Chemical cure silicones release vapour which can damage the circuitry
