Removing doorcards for a polo 6N2
Tim_GTi
Post Whore
Post by Tim_GTi »
you need to do this for a variety of things, changing speaker, mirrors, altering doorpins. This particular guide is for replacing the grab handles which are common for flaking.
I was really reluctant of doing this first time, done it about 5 times since with no problems!!!!
its really simple, you just need 3 tools
flat screwdriver, crosshead screwdriver, and stubby crosshead screwdriver
first grab the stubby driver and unscrew the the crosshead located underneath the tweeter casing, (this is the only thing you need the stubby driver for!)
you then need to grab the flat head and with one hand, pull the door handle slightly, and the other poke behind the grab handle insert to pop it out, like so;
(red arrow indicates direction of grab handle insert popping, white arrow indicates direction of screwdriver to obtain the pop!)
there's 3 clips holding the insert in, (you have to wiggle the bottom) to get it out, it should now look like this
unscrew the crossheads circled blue here.
the doorcards now ready to come off!
there's 'pop' clips all around the edge of the doorcard which you need to pop out, don't be afraid to give it some muscle, easiest place to start from I found was the bottom left of the door;
pop the clips all the way around the door until it is just held by the doorpin and handle (it'll still stay put on it's own here), gently lift the corner of the doorcard over the doorpin;
When the doorpin's clear all that's left is the chrome handle.
Pull the handle open, and with one thumb push it, with the other hand pull the doorcard off, the handle should gently slide through the hole. Make sure you keep hold of the doorcard!
looking down between the door and the doorcard you can see the wire and connector for the window switch,
make sure you unclip this BEFORE pulling the doorcard away. (on the driver's side there are 5 connectors, both window switches, central locking, the mirror switch and the alarm LED, they all come apart with a little playing)
and it's off!! you can now do whatever you were planning on doing, (if changing the grab handles, read on!),
sorry this is the only pic i got of the actual door,
take the doorcard aside and turn it around, there's 5 screw to undo (circled red)
front of the card should look like this
take this opportunity to give it a quick clean, mine was well dirty in the corners!
(unless you bought a new on) Make sure you unclip the cover on the old handle, it's the cover (that on the driver's side) is for altering the mirrors,
pushing one clip with your thumb releases all the others
put the new grab handle on (using the 5 screws on the back),
Now reverse the process. When putting the doorcard on, first connect up all the wires to the switches, then pop the doorpin back through the hole, open the door handle and feed it through, it's then ready to 'pop' all the pop clips back in place.
when everythings screwed back together sit back and admire!!
hope all is clear
JPR_polo_gti
Post by JPR_polo_gti »
top stuff!
An addition tim :) its best to remove the door pin....makes life that little bit easier!
JPR_polo_gti
only just noticed yours has black plastic door pins, did you change them to black? mine are chromed ones. another polo gti inconsistency?
chromed?! ive never heard of chromed OEM pins lol
ModifiedMadness
Sponsor
Post by ModifiedMadness »
The door pins were all black afaik.
A guide to how you shortened them would have been cool, I wouldn't mind doing mine.
JPR_polo_gti
one of the previous owners must have put them on... they look nice though and match the door handles.
Tim_GTi
Post Whore
Post by Tim_GTi »
yeh there chrome ones are aftermarket, there's already one on here Tom!
http://www.tigerstyle.co.uk/poloforum/v ... hp?t=32651
there you go, i didnt glue mine however, just pushed them back on and they don't budge a muscle! keeps it clean that way
Ollie_R
Sponsor
Post by Ollie_R »
Bump for this thread :D
I would like to say that this is an excellent and informative guide. I managed to take the door card out, take out the manky old handles and replace them with nice new handles within 20 or so minutes!
Cheers Tim 8)
Tim_GTi
Post Whore
Post by Tim_GTi »
Ollie_R wrote:Bump for this thread :D
Cheers Tim 8)
no problem mate 8)
Polo96CL
Post by Polo96CL »
Is there much difference between the 6N2 doorcard removal and the 6N doorcard?
Tim_GTi
Post Whore
Post by Tim_GTi »
Polo96CL wrote:Is there much difference between the 6N2 doorcard removal and the 6N doorcard?
It will probably be the same concept: a few screw removals follwed by clips, but i couldnt say its exactly the same
Its almost identical, just the window winder unclips rather than unscrews
Zero-Tolerance
Post by Zero-Tolerance »
where'd you get the grab handles from tim? mine are nasty looking!!
cheers!
From your local dealer or vag parts - both sides is about £25 to do it all :)
