VW Polo MKIV Raceland Coilover Fitting
what you need on the 6n is a 4 wheel allignment not just tracking and toe in / out
i fitted springs and dampers to mine not realising this and ate a set of tyres i got quoted £80 for a 4 wheel set up yet had it done for £20
a new set of tyres cost £70 for the front so dont skimp on this and get it set it will also be the final tweak to your moded set up i am however considering these raceland coilies ! were they of ebay ? pretty good price ! ay
ps great write up
ps great write up
Ive fitted these to my car but not sure if its right.bstardchild wrote:Again there are parts from the old shocks that are required
from left to right in the pic-
1. nut
2. bush with bearing
3. top of old suspension? _ Is this required as i did not use any parts from my old suspension- just bought new bush and bearing // PLease help!!!
- Tim_GTi
- Post Whore
I kept the bumpstops (foam bits) as I didn't use the ones on the new kit.shaunfrazier wrote:hey guys im fine for the rears but the fronts im slighty cofused on which part i need to keep.
anyone else got any pics i can see?
thanks
shaun
And the whole top mount (whole black rubber section at the top)
- jezza
- Location: Yeovil, Somerset & Essex Drives 1.6 6N polo and a G40.
Re: VW Polo MKIV Raceland Coilover Fitting
Fitted my coilovers and have come across a problem. The front two are not sitting properly inside the engine bay mounting plates. They are bottoming out. The top plate is already touching the underside rubber mount and wont sit properly. It sits about 10mm above. Has anyone had this problem. If they have what did they do to overcome this problem
Looking at fitting coilovers to my mates 6N at the end of the week.
From what I understand camber can be set up roughly with a spirit level as the holes are slotted. But what’s this about the toe needing adjustment surely this should remain unaffected?
