My rear window washer has stopped spraying water, I can hear it working and when i look water is coming out by the boot lock.
My quick question was does the 'door card' looking bit on the back pop off like normal door cards?
Has anyone else experienced this?
Regards
Rear washer
- charliec125
- Tim_GTi
- Post Whore
Re: Rear washer
Your pipe must have split. don't use it anymore to avoid any further damage with the boot lock or alarm.
There are to torx head bolts in the handles of the bootlid, undo them then just carefully pry off the plastic panel
Re: Rear washer
Looks like mine has got the same problem. So going to removal the door card and check for splits etc.
Are the rear wiper assembly easy to come by ? As ours doesn't have a cover/ bolt cover for the nozzle section etc
- Tim_GTi
- Post Whore
Re: Rear washer
Waht du mean easy to come by? As in find a spare? Must be pretty easy as alot of people have de-rear wipered. me included
Re: Rear washer
had this problem on mine dudes, was the pipe that had came off the wiper connection. easy to fix, if i remember correctly the panel with the handle in the boot just came off without much effort. fired the hose back on and hey presto!
