How to install RClick Remote Central Locking Kits
Post Instructions on DIY modifications here - use all information with caution!
hedgeville
Re: How to install RClick Remote Central Locking Kits
Post by hedgeville » Thu Mar 13, 2014 8:50 pm
Hi Alex
After some time away from this project - just wanted to update you all...!
After further inspection of the door hinge and exposing the connecting rubber shield - discovered the wiring loom ....the blue and white wire was there!
I followed it back through in to the car with some difficulty simply due to its location and finally viewed the same blue & white wire.
Managed to strip some of that lovely real sticky tape back and crimped the lock&unlock wire on to it.
Hey presto its working...
Many thanks for you advice, encouragement and most importantly technical knowledge.
Regards
Countdown
Drives: Polo 6r 1.2 S
Post by Countdown » Mon Oct 27, 2014 8:41 pm
doubledot
Drives: 6N2 1.4 16v
Post by doubledot » Mon Mar 27, 2017 1:00 pm
Hey guys, resurrecting this topic..
Fitted an Rclick to my 6n2, works like a charm thanks to this guide, cheers man! 8)
However, the blinking indicators don't seem to work. Have turned on the indicator and checked with a voltmeter and it is deff the right wire but somehow no response coming from the brown wire(s). Any thoughts?
oh and yes, I've installed it at the vacuumpump and picked up the indicators at the taillights.
alexperkins
Site Admin
Drives: 91 Golf GTI, 06 9N3 TDI, 11 Tiguan TDI
Post by alexperkins » Mon Mar 27, 2017 3:26 pm
That normally works. Is there no output on the brown wires?
Can you hear the relay clicking?
doubledot
Drives: 6N2 1.4 16v
Post by doubledot » Mon Mar 27, 2017 10:02 pm
Yeah, weird right? Have been using the system for half a year or so now and have had no trouble whatsoever. The lights were on my 'whenever you have a spare day with sunshine'-list and were hooked up this weekend. Will try to fit a voltmeter to the brown wires tomorrow and check for pulse on keypress.
alexperkins
Site Admin
Post by alexperkins » Mon Mar 27, 2017 10:04 pm
Very odd. You'll hear the relays click as they are quite loud
doubledot
Drives: 6N2 1.4 16v
Post by doubledot » Tue Mar 28, 2017 8:49 pm
Got it to work today! Traced it back to a dodgy contact hidden inside all the heatshrink in the brown wire (where they split into two wires). fiddled with these contacts and after seeing it work, wrapped it up again for insolation and all good now :) Cheers mate!
