How to upgrade your RCD-310 to a Sat-Nav RNS-310
Drives: 91 Golf GTI, 06 9N3 TDI, 11 Tiguan TDI
Re: How to upgrade your RCD-310 to a Sat-Nav RNS-310
Post by alexperkins » Fri Feb 26, 2016 11:05 am
Goodo. Should work fine there
It does sometimes take 20-30 mins to pick up a signal first time around
Is it currently in germany somewhere?
Bigtam
Drives: Polo GTI 2016
Post by Bigtam » Fri Feb 26, 2016 11:14 am
No bought it from a guy over on Briskoda and he is in Crawley and it comes up around that area
Bigtam
Post by Bigtam » Fri Feb 26, 2016 12:01 pm
Thanks for your help Alex.Just checked the Nav and the unit cant see any satellites will check it tomorrow and see if it works then if not will buy a new GPS aerial.Do you know what coding I have to do for to get the mic working on the steering wheel.
Post by alexperkins » Fri Feb 26, 2016 12:03 pm
Sounds like its definately not receiveing the satellites then. The connections are quite fragile on them - thankfully inexpensive to replace though.
Afraid not without looking. Itll be in the long coding helper on the radio settings i imagine.
Bigtam
Post by Bigtam » Mon Feb 29, 2016 3:45 pm
Working now it was a dodgy GPS antenna
Post by alexperkins » Mon Feb 29, 2016 4:09 pm
Happy days
Polo1971gti
Drives: Polo gti
Post by Polo1971gti » Mon Jan 02, 2017 9:48 am
Hi there links where to buy the microphone mine has never worked
Got to use my phone on loudspeaker when makin a call
My music does Bluetooth ok
