*The attached sceenshots of VCDS coding to be used at own risk*
Click on "Select"
Click on "09-Cent. Elect"
Click on "Long Coding Helper"
After all Selections are made, Click on "Exit"
Then Click on "Do It!"
VCDS - (2013) Central Electronics Control Module Long Coding
This is going to be SO helpful to me because I don't have any labels on mine for my rline. Thankyou very much!
Re: VCDS - (2013) Central Electronics Control Module Long Co
Looks great thanks for the info,
What if i exchange my bcm?
Just copy and paste in to the new bcm?
Or is there more to do?
Hope u can help me!
Thanxs a lot!
Hope u can help me!
Thanxs a lot!
Re: VCDS - (2013) Central Electronics Control Module Long Coding
Any chance this topic could be updated? Pictures aren't working
BCM Coding
Please note not all Polo 6R GTI's have the same BCM's, my Polo has got a 090 MAX module. Some of the coding may not be accepted on the older BCM's.
Stock coding.
Static cornering light activate with reverse gear. Byte 21, change Bit 3 from 0 to 1.
Stock coding for DRL LED's
DRL LED Wink. Byte 23, Bit 7
DRL LED's off when handbrake is up. Byte 23, Bit 4
Stock coding.
