6N2 - Retro-fitting OEM fogs
Hey Phil, the switch on the lower spec models only activate the rear fog light. You need the switch that does the front ones, like This.
Also, if you're fitting fogs, you may need to extend the wiring for the fogs. The wiring for the drivers side fog light was too short, so I had to splice some wire (fortunately provided by VagParts in my fog kit ) onto the previous wiring and also you may need to stick a new plug on the end.
