How to Reset Oil/Inspection Service Indicator
pettsy
Moderator
Post by pettsy »
May be handy for anyone doing your own servicing :wink:
Polo 1999-02
OIL-Oil service
Press and hold button (A) (Located on speedometer below LCD display)
Switch ignition ON
Keep button (A) depressed until "---" appears in display
Release button (A)
Switch ignition OFF
INSP- Inspection service
Switch ignition ON
Release button (A)
Switch ignition OFF
If required clear the "OIL" indicator from the display as previously described
Pettsy
lolhoward
Post by lolhoward »
Just what I was after, thanks
tompeters
Re: Oil/Inspection Service Dispay Reset Codes
Post by tompeters »
thanks for that it were doin me head in :?
kingsleysaywell
Post by kingsleysaywell »
so when this comes up does it mean my oil needs changing or what then?
Tim_GTi
Post Whore
Post by Tim_GTi »
kingsleysaywell wrote:so when this comes up does it mean my oil needs changing or what then?
Yes, unless the last person that changed you oil didn't reset it.
You should change the oil at least once a year or 10 000 miles. Some people even more frequent. Check the book to see when it was last done.
kingsleysaywell
ok thanks mate
olivia
OK, but... ??
Post by olivia »
Great instructions!! But do i need to change my oil filter and what hav you?? coz id rather not make a mess of my engine... more than i already hav done that is! :S xxxx
Tim_GTi
Post Whore
Re: OK, but... ??
Post by Tim_GTi »
olivia wrote:Great instructions!! But do i need to change my oil filter and what hav you?? coz id rather not make a mess of my engine... more than i already hav done that is! :S xxxx
it depends on when the last time the oil was changed, as it could've just been that the last person to service it forgot to reset the timer.
standard oil changing intervals are every 10k or annually. some people choose to do less though. check the service book on your car to see it was last done.
Tim_GTi
Post Whore
Re: OK, but... ??
Post by Tim_GTi »
Tim_GTi
Post Whore
Re: OK, but... ??
Post by Tim_GTi »
Verity
Post by Verity »
ah this was so useful! :D
was driving me nuts having the service display pop up.
nick6n2
Post by nick6n2 »
you legend wondered if there was a way to do this without a tril to vw thanks mate.. :)
jonny6n2
Post by jonny6n2 »
GREAT TIP
but will it come back up after 10,000 miles again?
Tim_GTi
Post Whore
Post by Tim_GTi »
jonny6n2 wrote:GREAT TIP
Yeh, IIRC it's every 10k, unless setup for a long service which is like 20k?
fackers89
Post by fackers89 »
hey tim alright?
did this on my car thinking na it wont work....well second time i did, just didnt wait long enough!
that think was bugging the hell outta me. thanks tim, + coming to the meet sunday?
