how much paint would i need for a wing
i need to get a new wing, just wandering how much paint i would need for the wing? also what other stuff would i need for painting it?
I really wouldnt spray it yourself!!! I spray surfboards and have done loads of car stuff its bloody hard work especially if you have a panel side by side.... If your car is Flash Red!!! def. get sprayed professionally, the pigment in red fades thats why you have pink polos!
Silver is a @£$%*!! too as it needs to be sprayed in a particular ' grained' direction otherwise you get patches and tone variations!!!
Get it done with some other mods like spoiler or something to make it worth while!!!!
Depends if your doing it properly or on the cheap. If its been done properly then it should be sprayed on the car, and blended into the door and bonnet. Though this will cost lots more as they have to re-laquer the door and bonnet. They do this as no matter how good a paint mixer you have it will never be a perfect match.
Dependent on what colour car you have you should be able to get away with having it sprayed off the car. Which is a lot easier and cheaper. If its a black magic colour car get it sprayed on as this colour is a nightmare to match. I know from past experience!
