Anyways, my W reg 6n2 polo just came back from having the rear lock and barrel replaced as the mechanism had gone to pot, and i have now discovered that the boot pistons/hinges dont work very well anymore.
When you go to open the boot, it starts lifting and just stops about 1ft out - so the door is nearly horizontal against you. Its a really odd problem! To open the boot you have to push the door up, or it will never open.
Has anyone else had this problem, and if so how did they resolve it (ie new pistons or a simple fix) - and otherwise, how do i go about getting it fixed
Cheers,
Alex
