Hi I'm new here so be nice
I've got a 6n2 1.4 se and it's on its 3rd fuel pump! I bought it as spare or repair thinking it was a dodgy fuel pump as the fuse was blown. So I bought a new one fired up straight away let it run for abit, parked it up went back the next day and......NOTHING! No humming sound from pump checked if there was power at the plug to pump and there was so went to scrap yard got another pump and fired straight up! Same again went back next day and nothing. Anyone had this problem? I've changed the fuel relay too and fully charged the battery, any suggestion?
Thanks in advance
Fuel pump
- Drives: Vw polo 2001 6N2
Re: Fuel pump
Best thing you can do is buy a brand new one any slight fault will cause it to blow the same thing happened to my polo but as soon as I bought a brand new one put it on and it was fine been a good year now and no signs of any problems good luckGirdla wrote:Hi I'm new here so be nice
Thanks in advance
- Drives: 2001 1.4 se
Re: Fuel pump
Hmm dunno if I want spend all that money on a brand new incase it does the same as the other [emoji52]
Re: Fuel pump
I know it's a risk but there's not much other advise I can give apart from taking it to a vw garage and let them have a look even that may be costlyGirdla wrote:Hmm dunno if I want spend all that money on a brand new incase it does the same as the other [emoji52]
- 937carrera
- Drives: 2000 Polo GTi
Re: Fuel pump
Try giving the "new" old pump a wash through / soak in diesel before fitting to the car. It will help remove any crud / rust which may have accumulated
Re: Fuel pump
I've stripped the last two pumps that have been fitted and both pumps are seized solid [emoji35][emoji35]
