1.0 MPI new oil leak
piglet14
Drives: Arosa
Post by piglet14 »
Quite wet all round sump but not making puddles yet.
Is there a favourite spot on these?
Re: 1.o MPI new oil leak
Its unlikely to be the sump. The gasket is a liquid gasket and doesnt tend to degrade over time. Its more likely to be the breather on the back of the block, or a leak from above.
piglet14
Drives: Arosa
Re: 1.0 MPI new oil leak
Post by piglet14 »
It's up the front of the pan as well, would a leaking breather get oil that far round?
I'll have to clean it up and take the belt covers off.
It can run around quite easily. The other possibility is a few loose bolts and it's coming down the thread
piglet14
Drives: Arosa
Post by piglet14 »
Where is the breather Alex? I'll check it out.
Back of the block. Follow the crankcase breather hose down from the airbox on the left handside.
piglet14
Drives: Arosa
Post by piglet14 »
Do you mean the black plastic casing that's screwed to the back of the block next to the starter? Quite manky round there.
The belt covers all look nice and dry so probably not seals.
Yeah that’s right
piglet14
Drives: Arosa
Post by piglet14 »
So what leaks then, O-ring or gasket?
Sometimes the breather cracks, the hose splits, the gasket perishes
piglet14
Drives: Arosa
Post by piglet14 »
Aww crap, You mean I've got to pull it all out & investigate.
You might be able to see it from underneath with a torch and mirror
To access it it’s normally a case of take the inlet manifold off for proper access
piglet14
Drives: Arosa
Post by piglet14 »
Access looks OKish from underneath but I can't tell what's going on above it.
Is there a physical connection to the manifold?
No it goes into the block. The manifold just gets in the way
piglet14
Drives: Arosa
Post by piglet14 »
Bit like the D/S from underneath then.
I'll have a go when I've finished drilling door frames.
