6N2 Engine/Gearbox swap
- Drives: 6n2
Basically just picked up an Xreg 6N2 1L mpi, and 4th gear blew itself up at 30mph. Im able to buy a 1.2l polo 9n engine and gearbox but am wondering if they will fit without too much modification.
Re: 6N2 Engine/Gearbox swap
Simple answer is no. The 9N is a completely different management system and uses canbus unlike the 6N2
You need either a 6N or a 6N2 box. Ideally the same engine size too or the ratios will be out
I have a 2001/Y complete 1.4 16v 3 door 6N2 with 12 months MOT going cheap with a very good engine and box, had head work, belts done etc with receipt.....
- Drives: T registered 1.4 16valve 3 door -silver
Hi Baldguy. I've just registered. We would appear to be similarly challenged going by our usernames!
The Polo you mention in your post. Is this still available please?
- Drives: 6n2
If out of this engine swap you happen to have a spare gearbox I'm here waiting
As cheap or free as possible.
Sent from my SM-G950F using Tapatalk
