Hi all my first post here after being told to join I have a 2000 w reg polo 1.4 16v and I'm getting fault code p1553 barometric/manifold pressure not plausible
After taking advice I've changed
Egr valve
Map sensor
Throttle body (set up as well )
Checked all vacuum pipes (replaced brake servo pipe due to cracks )
Checked timing (all spot on )
Coil pack
Blew out all pipes going to purge valve /canister etc
The problem I'm getting is the epc light comes on when driving if I hold a constant speed and it goes a bit jerkey turn key off and on and it's sorted again until I stick to a constant speed again it's ok accellarating and slowing just seems to be when staying at a constant speed .
Really am stumped what to try next
Help needed asap please desperate
Re: Help needed asap please desperate
Are you getting any other faulty codes?
This is normally caused by a dirty throttle body. Has it been thoroughly cleaned on both sides and adaptation performed?
Yes both cleaned really well and reset and adaption done
Was the map sensor new?
Not plausible sounds like the signal isnt getting rear properly from the sensor. Implies broken wiring or a dodgy sensor.
Hi yes brand new
Is the map sensor proving a reading in vcds
