Car key cutting
nath1992
Drives: 6n
Car key cutting
Post by nath1992 »
Looking for the best place to perchase a spare key, to get it cut and to get it programmed, VW want a stupid amount. Cheers.
Sent from my SM-G935F using Tapatalk
alexperkins
Site Admin
Re: Car key cutting
Post by alexperkins »
Hickleys.co.uk are very good if they are local ish to you
nath1992
Drives: 6n
Re: Car key cutting
Post by nath1992 »
alexperkins wrote:Hickleys.co.uk are very good if they are local ish to you
Hi naa just had a look and there way to far away, I live in Nuneaton/Coventry area.
alexperkins
Site Admin
Re: Car key cutting
They could supply and you should have a local locksmith that can cut laser keys. Then it’s just a case of getting it programmed
nath1992
Drives: 6n
Re: Car key cutting
Post by nath1992 »
alexperkins wrote:They could supply and you should have a local locksmith that can cut laser keys. Then it’s just a case of getting it programmed
To be honest the key cutting isn't the issue, it's getting a key with vw on and the programming. Was hoping to find someone who can do the lot for us.
