Arosa 1 piece exhaust
piglet14
Drives: Arosa
Post by piglet14 »
Back box has gone.
All I can find online is centre & rear sections
Mine is a VW stamped 1 piece.
Is this a case of cut & clamp the new rear on?
Re: Arosa 1 piece exhaust
Correct. They came one piece from the factory
Replacement will be cut and clamp.
piglet14
Drives: Arosa
Post by piglet14 »
Thanks Alex,
Looking forward to this one, not.
It’s fairly straightforward. Remove the entire one piece from the car, measure and cut then sleeve the new one on once refitted
piglet14
Drives: Arosa
Post by piglet14 »
All done, cut the pipe on the car rather than try and disturb the nasty looking joint behind the cat.
Bit fiddly but done worse.
Joint leaks a bit, don't know what's considered acceptable.
Used to use Gun Gum in the bad old days.
You are best to seal it up with gun gum. Needs to be fairly tight from a leakage perspective
