Radio
- Drives: 6n2 1.4 mpi 2000
Radio
Hey guys any idea how to wire an MP3 player to my car. The connections don’t fit and I have no clue how to fit them. Thank you!
Re: Radio
Ours had ISO connectors on the car loom already, so if your new unit doesn't have these it's usually easiest to get adaptors from the likes of Halfords or online suppliers. If you Google for 'standard iso car stereo wiring' you'll be able to see what that connector looks like and decide if that's what is in your car. It may be that someone has changed them at some point in it's life (or that's happened to ours, I don't know it was ISO when it was new)
Hope that helps. Simon
Re: Radio
I never thought of that Simon! I will check that!
Thank you for your help! Hamza
Re: Radio
All 6N2s had standard ISO plugs
Your radio should have a 'helper' loom to go from the radio to the cars loom included in the box
Radio
The radio wasn’t meant for the car it’s one of these
Re: Radio
Thats likely not got standard ISO then. Pop up a pic of the wiring it has
Re: Radio
Re: Radio
This is the wiring the radio has and the car has
Re: Radio
Ok, that needs one of these, and the cables joining together as appropraite
https://www.ebay.co.uk/itm/CT20UV03-Fem ... 0505.m3226
There should be a wiring diagram in the radio manual
Re: Radio
There is a wiring diagram I just have no idea how to do any wiring:(
Re: Radio
If you order one of those from ebay, and post up a scan of the wiring diagram, we can help you
Re: Radio
I have a quick question, I was driving my polo and while I was driving the red oil light was flashing and I’m not sure if it because there is low oil pressure or low oil level or if it has to do with the transmission oil level as it has a slight leak. Thanks for your help
Re: Radio
That’s low engine oil pressure. Get it checked. Sometimes the sensors go faulty over time but don’t risk it
Re: Radio
Hey guys, just a quick question, any idea why my car has trouble going into gear? It’s so annoying trying to change fro one gear to another and it has a hard time going into it. Thank you
