Telephone not available
Discuss In Car Entertainment
kurtbeyli
Drives: Polo 2015 Comfortline 1.2 TSI Bluemotion
Post by kurtbeyli »
Hi all!
I've recently removed my component protection on my new dab radio with bluetooth which I have retrofitted. So here is the problem, radio function, aux, sd card and cd is working properly. But when I press the phone button it says 'Telephone not available' and in the media section there is no bluetooth option, just sd card and aux option. If anyone has encountered the problem same as mine and successfully solve it, I would be really glad if he/she helps me.
Car : Polo 1.2 TSI Bluemotion 2015
Part number : 6C0 035 869 A
Have a great day!
Best Regards,
Kurtbeyli
Re: Telephone not available
Have you adjusted the coding on VCDS to enable the telephone function
kurtbeyli
Post by kurtbeyli »
alexperkins wrote:Have you adjusted the coding on VCDS to enable the telephone function
No I didn't. Thats what I'm gonna do tomorrow, do you think that will solve the problem?
kurtbeyli
Post by kurtbeyli »
Okay I've solved the problem. For the people who suffers from the same problem, you just need to code your infotainment system via vcds just like @alexperkins says. My vag expert said that the radio was never coded in the first place. He found the code on the internet(I don't know where he found it) then he coded via long custom coding and it worked like a charm :)
