Strange CD player issues , please help me !
Discuss In Car Entertainment
dannib89
Drives: 2001 Polo mk4/6k saloon tdi 110
Post by dannib89 » Fri May 04, 2018 10:25 am
Hi guys , now this is strange .. changed my ignition barrel which is a simple job and after it was all back together it worked as it should , apart from the CD player .. so I figured ah blew a fuse so checked both fuses (cd player and car) and they are fine , checked all wires+earth e.t.c and good . Tried 2 other aftermarket cd players as I assumed I blew the unit and no luck ... However the original tape player and another original cd player from my other polo both work !!?? So getting power and even earthed the player as I understand some aftermarket players need another earth to chassis , ,, so wireing good , fuses good .. any ideas ?
Vehicle is a 2001 vw polo saloon 110 TDI
alexperkins
Site Admin
Drives: 91 Golf GTI, 01 TT 225, 67 Q7
Re: Strange CD player issues , please help me !
Post by alexperkins » Fri May 11, 2018 4:19 pm
Hi there
What CD player do you have - in dash or in boot?
These CD changers are notorious for being unreliable
Have you changed the ignition switch? Sounds like the 15 terminal on the ignition switch has an issue
