After i bougt some spacers, i went hunting for some locking nuts.
Thing is they are quite expensive, and only works with one setup, making it a pain if you at some point choose to go for a different size spacer etc.
I came by this solution, that appears to be the Big hit overseas.
Eurasia Black top
How it works is quite obvious
They Fit 17mm and 19mm
I bought my set from Amazon
Maybe usefull for others?
/ *L*
Wheel locking nuts + spacer
- ImageUploadedByTapatalk1448800083.864526.jpg (95.23 KiB) Viewed 3532 times
