Burnt valves and way ahead (BME swap AZQ)
Discuss Engine, Gearbox and Exhaust
ThomasJ
Drives: 1.2 BME S64
Post by ThomasJ » Tue Sep 05, 2017 8:55 am
Hi all, need your expert advice:
I drive Polo 1.2, Petrol, S64 with BME Engine. It has the dreaded valve issue.
I have 2 choices
(1) Take the head off and get it overhauled
(2) I have another engine, but it is AZQ. Does anyone know if this is the same engine. Its is out of a Skoda 2003, 1.2 Fabia with 50’000 less miles than mine and seems to have no problem.
So what do you think is best option – Head overhaul or engine (AZQ) swap?
Everyone – thanks for your knowledge, Tom
alexperkins
Site Admin
Drives: 91 Golf GTI, 01 TT 225, 11 Tiguan TDI
Re: Burnt valves and way ahead (BME swap AZQ)
Post by alexperkins » Tue Sep 05, 2017 10:29 pm
You cannot easily swap a B series engine to an a series. They are mechanically different and also electrically different
A head overhaul isn’t that much work. I would go down that route personally
ThomasJ
Drives: 1.2 BME S64
Post by ThomasJ » Wed Sep 06, 2017 4:52 pm
Many thanks for for guidance.
So I will set the AZQ aside and figure out what to do with it later.
That leaves me with taking the head off and getting Valves done.  My Dad has I believe a good garage of tools except the timing locking set.
May I ask is it a complicated job?  I am a little intimidated by the timing for the three cylinder so everyone - any advice would be greatly appreciated or are there any other big issues or problems in taking head off and replacing.   What other costs would i need to build into the project.
By the way - an engineering works has costed me 180 plus vat worst case for the head overall.
Great - Thanks all and know that advice is appreciated!!
