GTi: Throttle Body Cleaning Not Working
Scream
Post by Scream »
Hi guys. Got a 6n2 GTi and I had the juddering problem. Gave the throttle body a clean on Saturday and it was filthy. It worked a treat until yesterday when the problem started again. Car keeps juddering around 1000-1500 revs before picking up speed again. Anyone know what might be causing it? I had a look at the throttle body again today and it was fairly clean. Pretty stumped as to what might be causing the juddering.
lowfoon
Re: GTi: Throttle Body Cleaning Not Working
Post by lowfoon »
I had a juddering problem and it was driving me insane trying to figure out what it was...
I then decided to get a VAG cable and narrowed it down to my lambda sensor having a short to ground connection, after clearing this there was no judder at all :D
Basically, it can be a number of things but a VAG cable can help you narrow it down.
emma_88
Drives: 6N2 Polo GTi & 9N3 Polo GTi
Post by emma_88 »
Yep, as said get someone with vag-com to scan your car.
lowfoon
Post by lowfoon »
emma_88 wrote:Yep, as said get someone with vag-com to scan your car.
I have if your local :D
polo naz
Post by polo naz »
hi there mate,i got a vw polo n reg 14,i got the same problem,try changing the temperature sensor?
