How to attach pressed plates?
- lolhoward
I know a lot of you have attached with tape or velcro but i'm quite worried of them being ripped of. I know people that it has happend to. So just wondered if there were any other options before I decide to drill holes into them and mount them as you do standard plates. Any help/advice would be appreciated, cheers
Re: How to attach pressed plates?
What about a set of the 'snap' together german style plate surrounds? If your still bothered over them being taken if you had them, then glue the outer trim on for extra safety!
- lolhoward
So do the surrounds attach via the screws then and the plates sit inside them?
Yep, if you buy the decent german style ones off dubmeister etc. Cheap surrounds that screw thru' plate are rubbish!
- lolhoward
cool cheers mate. I weren't sure if they attached like that or just went around the edge. I'll order some up then.
Sure they are like a press style fit that use's a tool to remove them. Best is to email dubmeister to clarify the fixings for ya!
- Tim_GTi
- Post Whore
Screwfix Foam tape. Good strong stuff
- lolhoward
Yeah thats whate i've decided tim. Will look much better than screwing them on. Got some 3m tape and halfords numberplate pads (which look like 3m tape). Heard its pretty strong stuff. My badge hasn't fallen off yet
heat the tape with a heat gun before sticking the plate on works alot betta then
- lolhoward
Cheers for that mate but tried that and still no good. Stuck to the bodywork but not the plates. Especially the front due to the curve ,so screwed them on. Doesn't look as bad as i thought though.
- charlievwp
I just got myself some of these. Easy, cheap and look great!Torq-Al wrote:What about a set of the 'snap' together german style plate surrounds? If your still bothered over them being taken if you had them, then glue the outer trim on for extra safety!
