number plate on grll
Can anyone help. How can i put my number plate on the front lower grill without drilling holes in the plate . Dont fancy drilling because there are the metal pressed ???
Re: number plate on grll
I just done mine last night dude. Came out fine, if you've got the 'legal' pressed plates then there's two materials, the aluminium backing /numbers and the reflective sheet around it. They started to separate a tad when I drilled them but drop of glue and was fine. Think that's the only way unless you mount something to the back of the plate then mount that to the grill
I used some sticky pads seald them rwnd plate and tie back from grill but ashame car caught fire nothing left and ive moved on
Has anyone got pics of this sounds awesome?
I havent am afraid no
Ok thanks anyway, I'll have a look round and if I find any i'll post them up
If you look at my post there is a pik with the plate already on but doing it is easy lol
