Removing Swirl Marks Black Paint
Detailing & Bodywork
Yeahhluke
Post by Yeahhluke »
Best way to do this anyone? Products used?
ta 8)
Mark M
Re: Removing Swirl Marks Black Paint
Post by Mark M »
Will need cutting compounds and pads.
Most original vag paint is hard, so depending on the defects you may need to be aggressive.
Have you got a DA or Rotary?
Yeahhluke
Post by Yeahhluke »
By hand unfortunalty :?
joe2612
Location: Guildford, Surrey, Drives: Polo GTI 6n2 Black
Post by joe2612 »
Depending on the depth of the swirls you'll be hard pushed to remove them by hand. As an alternative you can fill them temporaraly with a glaze such as poorboys black hole which is excellent for black paint. Seal it with some decent hard wax and that should improve the finish and hide some of the lighter swirls.
Joe
Yeahhluke
Post by Yeahhluke »
Cheers ill give that a go! ive always heard good reveiws and want to try the poorboys range so this will give me an excuse :D
greypolo9n3
Drives: white 6r 1.6 tdi rline/gti
Post by greypolo9n3 »
1200/1600 grit paper depending on how bad it is - WET application
Buff with coarse compound (3m fast cut - greentop)
Polish off with 3m bluetop (ultrafina)
then polish again with normal polish if you wish
aarongti
Post by aarongti »
greypolo9n3 wrote:1200/1600 grit paper depending on how bad it is - WET application
Pretty bad advice tbh.
Why would you suggest methods that would sacrifice clearcoat when there are much better n safer methods.
Also 3m blue is not enough to remove the marring from FCP,
greypolo9n3
Its how any bodyshop would do it unless a respray is needed
aarongti
Post by aarongti »
Exactly.. Bodyshops are bodyshops not detailers.
greypolo9n3
aarongti wrote:Exactly.. Bodyshops are bodyshops not detailers.
So how would you do it
aarongti
Post by aarongti »
Start off with a medium polish on a soft polishing pad in a rotary.
Megs 105 on a 3M polishing pad. If results are found then continue with this combo.
If more aggression is needed same polish but step up to firmer pad or even wool or microfiber pad (DA only).
Then refine on soft finishing pad with Megs 205.
Be sure to take paint readings in all areas and monitor clearcoat removal rates.
A swirl free finish should then hopefully be yielded.
A nice gloss should appear also.
6REA211
Drives: 1.2 SEL
Post by 6REA211 »
Gtechniq P1 and their double sided applicator is worth a look if you need to remove light/medium swirls by hand.
Longman
Drives: Polo 6r gti
Post by Longman »
aarongti wrote:Start off with a medium polish on a soft polishing pad in a rotary.
Mine will be like that one day :D
