BMC Group Buy
- Sponsor
From looking at my car and speaking to BMC it appears that some 1.6 GTi 16v models have the oil breather pipes running into the standard airbox. In these models a breather filter is also required. the price for this kit would be £160.49 delivered which is still cheaper than europerformance & POTN who do not provide this breather filter...Kam Racing wrote:anyone else fancy a BMC CDA kit for their car?
worked out that the price i could get people the CDA kit for the 1.6 GTi 16v would be £149.99 delivered
i could set up the GB if needed on bmc, modesl not requiering the breather filter would be £145 delivered(includes the silicon connecting pipe as well which is usually an extra £10) and if breather pipes needed woud be £155(includes silicon pipes as well)
only one that would be more is the 1.9tdi 110bhp model as it requires a larger filter, it would be £165
Baz I'm speaking to another distributer of these on Tuesday so hopefully I can get a slightly better price. Would you be interested in one if I could get a better price than yours? The rubber bend is no longer available so all kits that need the bend have to use the silicon one...BAZ C wrote:i could set up the GB if needed on bmc, modesl not requiering the breather filter would be £145 delivered(includes the silicon connecting pipe as well which is usually an extra £10) and if breather pipes needed woud be £155(includes silicon pipes as well)
these are the latest prices...
CDA kit for 6N & 6N2 1.4 16v £160.00 Delivered
CDA kit for 6N2 1.6 GTi 16v (with breather filter) £160.00 Delivered
CDA kit for 6N2 1.6 GTi 16v (without breather filter) £144.50 Delivered
CDA kit for 6N & 6N2 1.9TDi £163.49 Delivered
CDA kit for Lupo GTi £144.50 Delivered
Re: .
you are correct.. the 1.4 16v kit needs a breather filter too and i have included that in the price.Omz_6N2 wrote:Kam im sure my 1.4 16v has the breather going into the original airbox like the GTI.
I'm unsure whether all GTi's need the filter as I can only look at mine which definately needs it... I have offered the two prices just incase VW changed it on the later models (the Lupo Gti has the same engine but doesn't need it)
