polo 6r 1.2tdi light faillure on dash, no error.
martijnoss
Drives: polo 6r
Post by martijnoss » Wed Jun 06, 2018 6:24 pm
Hello guys
I have a little problem, tha last weeks i was experimenting with canbus led, but i have nothing but failures so i set it back to halogen.
Now i have no error but on the dash is still my light on from the bulbs.
What can i do about it.
I have clear the errors multiple times but it has no effect?
Thanks for youre time.
Wednesday,06,June,2018,19:00:59:18846
VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.1
www.Ross-Tech.com
VIN: WVWZZZ6RZCY018898   License Plate: STORING LAP
Mileage: 211690km-131538mi   Repair Order:
Chassis Type: 6R-VW25 (6R0)
Scan: 01 03 08 09 15 17 19 25 2E 37 44 56 61 77
VIN: WVWZZZ6RZCY018898   Mileage: 211690km-131538miles
37-Navigation -- Status: Malfunction 0010
Address 01: Engine (J000-CFWA)       Labels:. 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 B    HW: 03P 907 425
   Component: R3 1.2l TDI   H06 9979
   Revision: 12005001    Serial number:
   Coding: 00114014032401080000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_ECM12TDI03103P906021B 001042
   ROD: EV_ECM12TDI03103P906021AA.rod
   VCID: 270A0BADFF698DDF10D-8072
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210224E3416E00BA842D24EB82D900521300
   Shop #: WSC 00788 648 00255
   VCID: 074A6B2D1F69ADDF30D-8052
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 3828D8D122571227897-806C
   Part No SW: 6R0 937 088 F    HW: 6R0 937 088
   Component: BCM PQ25 Re4  H50 0351
   Revision: BU050001    Serial number: 0456 157110196
   Coding: 3AB02BBF08F32400B3300F306DAB8ED00F80670F7E862401200000000000
   Shop #: WSC 124697 483 00190
   VCID: 41DEB535718D53EF3E9-8014
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 030611 05  54  0403
   Coding: 02302D
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU021021440524279
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU021021440524087
   Coding: 1000AB
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 7 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  007 1611
   Serial number: KU0-KU020.01.1111358
   Coding: 08BC32
   Subsystem 8 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU027051100015346
   Coding: 48BC32
   Component: VW10Airbag01M H09 0020
   Revision: --------    Serial number: 003GX00NYMLN
   Coding: 00314D
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACC92194C3B90B7EF3-801E
   Serial number: 3575HRB405R0ILP0CPGD
   Serial number: 3585HRB40510ILP068LD
   Serial number: 3515RRB404P0K4DOE8S8
   Serial number: 3525RRB40510JNPM88S8
   Part No SW: 6R0 920 861 H    HW: 6R0 920 861 H
   Component: KOMBI         H03 0505
   Coding: 140801
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 3A2CC2D91CDB00377F3-806E
Address 19: CAN Gateway (J533)       Labels:. 6R0-907-530-V2.clb
   Part No SW: 6R0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H38 0034
   Revision:   H38       Serial number: 310511F1000209
   Coding: 2500C2
   VCID: 3430ECE13E3FF647A5F-8060
   Component: IMMO          H03 0505
   Serial number:
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8C32992CFB70B7CF3-803E
   Part No SW: 5N0 035 342 E    HW: 5N0 035 342 E
   Component: SG EXT.PLAYER H13 0240
   Revision: A1001003    Serial number: 7660151535
   Coding: 020000
   VCID: 290E0D95E9FDBBAF069-807C
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 1T0 035 680 P    HW: 1T0 035 680 P
   Component: RNS-MID       H10 5238
   Revision: AB001001    Serial number: VWZ6Z7J2224002
   Coding: 00010400000000000000
   Shop #: WSC 12345 123 12345
   VCID: 3B22C7DD1361393F645-806E
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V15  8515
4 Faults Found:
00859 - Line-Output; Front Right
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 8
                    Mileage: 211680 km
                    Time Indication: 0
00823 - Line-Output; Front Left
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 8
                    Mileage: 211680 km
                    Time Indication: 0
00869 - Line Output; Rear Right
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 8
                    Mileage: 211680 km
                    Time Indication: 0
00860 - Line-Output; Rear Left
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 8
                    Mileage: 211680 km
                    Time Indication: 0
   Part No: 6R0 423 156 B
   Coding: 11260
   Shop #: WSC 00788
   VCID: 2F3AE38DDE59D59FD8D-807A
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
4 Faults Found:
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 8
                    Mileage: 211680 km
                    Time Indication: 0
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 8
                    Mileage: 211680 km
                    Time Indication: 0
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 8
                    Mileage: 211680 km
                    Time Indication: 0
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 8
                    Mileage: 211680 km
                    Time Indication: 0
   Part No SW: 6R0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H38 0034
   Coding: 030B1A5A
   VCID: 74B02CE17EBFB64765F-8020
   Subsystem 1 - Part No SW: 6R0 915 181 D    HW: 6R0 915 181
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900615949
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 G    HW: 7P6 035 730 G
   Component: TELEFON       H09 2730
   Revision: 1B001001    Serial number: 00007660128307
   Coding: 0800000000000210
   ASAM Dataset: EV_UHVNA A01015
   ROD: UHVNA.rod
   VCID: 3634D6E928C3E4579BB-8062
End----------(Elapsed Time: 01:54, VBatt start/end: 12.2V/12.2V)-----------
Drives: Polo 6R 1.2 TDI
Re: polo 6r 1.2tdi light faillure on dash, no error.
Post by iichel » Wed Jun 13, 2018 9:20 pm
do you connect your canbus LED to powertrain or comfort CAN?
martijnoss
Drives: polo 6r
Post by martijnoss » Sat Jun 16, 2018 9:43 pm
I put all the original lights back and now no errors.
