2008 polo rev counter problem
gaurav18
Drives: 2008, 1.2 match 60
Post by gaurav18 »
I have recently bought a 2008 1.2 polo. Everything works fine in terms of warning lights and speedo. However the revcounter seems to jam and jump up to a few thousand revs and slowly sit back down. Almost as it lags
Is there any solution to this, doesnt bother me to much but i was just wondering weather its a major fault
Re: 2008 polo rev counter problem
Could be a bad earth or a fault in the clocks. Theres a common issue emerging with dry solder joints where the clock plug into the wiring loom - this could be that.
gaurav18
Post by gaurav18 »
alexperkins wrote:Could be a bad earth or a fault in the clocks. Theres a common issue emerging with dry solder joints where the clock plug into the wiring loom - this could be that.
Thanks alot mate. Im not too good with electronics so ill take it to my uncles garage hopefully can solve the problem there
