Bluetooth media audio greyed out (bluetooth retrofit)
Posted: Sat Nov 24, 2018 9:44 pm
I have just retro fitted a 7P6 035 730C bluetooth module in a VW POLO 6R with a Bosch RCD510. The installation was pretty straight forward and the calls work fine from the head unit. Now my understanding is the module is a 9w7 and should be capable of a2dp music streaming? The problem I have is when I click media, bluetooth media audio is greyed out. As it stands, no VCDS coding has been carried out on the car as the installation I was following from another forum indicated that the kit wprks plug and play (coding wpuld be required for the instalmental cluster to work but as my POLO has a mid line display which isn't capable to phonebook navigation, caller id etc, coding isn't required. I jave also enabled the option under bluetooth on the RCD510 but it hasnt changed the option from being greyed out.
Is my Module capable of the a2dp streaming?
Am i missing some coding to get it to work?
I have spent hours reading posts trying to get answers but I am now just finding myself reading the same posts and getting no answers.
Any help or advice would be greatly appreciated.
