Sub power cable through firewall
Chat about your MKI or MKII Polo (86 and 86F)
alexperkins
Site Admin
Drives: 91 Golf GTI, 01 TT 225, 67 Q7
Re: Sub power cable through firewall
Post by alexperkins » Sat May 05, 2018 1:00 pm
alexperkins
Site Admin
Post by alexperkins » Sat May 05, 2018 1:01 pm
That’s the only photo I could find of mine. You should be able to work out where i routed it via though
TheRealRyno
Drives: Mk2 Polo F
Post by TheRealRyno » Sat May 05, 2018 1:45 pm
Yeah I tried that one aswell I've just been struggling to remove the grommet. It's a lot harder than the first one. What's the best method?
alexperkins
Site Admin
Post by alexperkins » Sat May 05, 2018 1:49 pm
Squeeze and pull though I have a feeling a pierced a hole in it and siliconed it up
TheRealRyno
Drives: Mk2 Polo F
Post by TheRealRyno » Sat May 05, 2018 1:51 pm
I've removed it but the grommet looks designed to just hold one wire. So how do I protect the second wire from rubbing against the metalwork?
alexperkins
Site Admin
Post by alexperkins » Sat May 05, 2018 1:53 pm
Post some more photos if you can
TheRealRyno
Drives: Mk2 Polo F
Post by TheRealRyno » Sat May 05, 2018 1:55 pm
TheRealRyno
Drives: Mk2 Polo F
Post by TheRealRyno » Sat May 05, 2018 1:56 pm
What if I was to slit it open one side and wrap it round both wires then just push it back into the hole. Would something like that work?
alexperkins
Site Admin
Post by alexperkins » Sat May 05, 2018 1:57 pm
That’ll work. Do that 👍🏻
TheRealRyno
Drives: Mk2 Polo F
Post by TheRealRyno » Sat May 05, 2018 1:58 pm
Okay I'll give it a go thanks for your help. I'll post later to let you know how it goes.
TheRealRyno
Drives: Mk2 Polo F
Post by TheRealRyno » Sat May 05, 2018 6:42 pm
Took a while but I got it all sorted and wired up in the end. Cheers for your help Alex. Much appreciated.
