1989 polo ranger keeps cutting out wen i drop down a gear
Chat about your MKI or MKII Polo (86 and 86F)
April1988
Post by April1988 »
hey i have a 1989 polo ranger 1.3...
when i put my clutch in to change gear and slow down the engine cuts out and occasionaly loses power. can any one tell me what might be wrong? The engine still idles fine and it dosent cut out every time i gear down.
Thankyou
mk2matt
Post by mk2matt »
could be carb freeze or a air leak on the carb mounting mate
try spraying carb cleaner in carb when running and after thats cleared
spray around base of carb and listen for any difference in engine idle
make sure you have all the pipes on properly and if needs be have the warm air feed secure
