IMPORTANT ALL MEMBERS
All members need to read the following page The new General Data Protection Regulations 2018 (GDPR)
Failure to read and accept the new privacy policy may result in your account being deleted, so please take a quick read
The UK-Polos.NET Admin Team
Spluttering help needed
Chat about your MKI or MKII Polo (86 and 86F)
Turbodan1
Post by Turbodan1 » Mon Dec 09, 2013 1:03 pm
Woke up to a non starting polo called aa out he got it running by cleaning the distributar cap now mis firing hard on drive but ok on idle, So I changed dizzy cap , rotary arm and plugs starts ok runs fine until you put your foot down hard on the accelerator the is splutters any one can help plz would be a great help .
alexperkins
Site Admin
Drives: 91 Golf GTI, 01 TT 225, 67 Q7
Re: Spluttering help needed
Post by alexperkins » Tue Dec 10, 2013 4:02 pm
Sounds like a fuelling, or air leak problem
Check all the hoses.
Yas_246
Post by Yas_246 » Sun Dec 28, 2014 2:56 pm
Check air intake
breadvansteve
Drives: polo 2f
Post by breadvansteve » Sat Jul 11, 2015 2:10 pm
check the wires on the injector. I had a similar problem a few years ago and it turned out one of the wires had worn through and was arcing and wouldn't run right. I changed the plugs, leads, dizzy cap, rotor arm, I even did the head gasket cos of the way it was running. all that for 1 pissy little wire.
