IMPORTANT ALL MEMBERS
All members need to read the following page The new General Data Protection Regulations 2018 (GDPR)
Failure to read and accept the new privacy policy may result in your account being deleted, so please take a quick read
The UK-Polos.NET Admin Team
1984 MKII Polo Breadvan cutting out, refusing to start.
AidanC98
Drives: MK2 1984 Breadvan
Post by AidanC98 » Tue Oct 11, 2016 2:29 pm
My car started playing up a couple of weeks ago, stalling constantly. We traced the problem to, what seems to be a fairly notorious issue, the rubber carburetor gasket which seemed to have cracked and was taking in too much air, causing the engine to stall. We resealed that, and for a day or two, it ran perfectly. On the way to work the other morning, the engine cut out and refused to start again. I had a look under the bonnet and noticed one of the HT ignition leads had broken. Still, however, the car will cut out while idling and often won't start again.
It also smells incredibly gassy, and upon inspection of the spark plugs, the engine appears to be running rich. I've adjusted the mix screw, idle speed to what should be about right, but to no avail.
I've replaced HT leads, new air filter, fuel filter, rotor arm, new points and tried a new fuel pump but ended up getting a faulty one that ended up with the car breaking down in rush hour traffic!
Hopefully you'll know something that I don't, cheers!
Aironeuk
Drives: Bora,Mk2 Breadvan,Mk2 Ocavia Estate
Re: 1984 MKII Polo Breadvan cutting out, refusing to start.
Post by Aironeuk » Sat May 06, 2017 5:08 pm
Have you replaced the carb mount??
How exactly did you repair the old one??
