Skoda Fabia VRS 2012. Auto lights retrofit OEM
Forum to discuss the Skoda Fabia
exantas
Drives: Skoda Fabia 5J 1.2 TSI
Re: Auto lights retrofit
Post by exantas » Sat Aug 03, 2019 1:12 pm
ciclo wrote:1
Ciclo
Why do you replace the can bus cables to the IC? Is there a bcm level above which you have to change the cables to the IC?
For example if we upgrade bcm 86 to 87, is this change needed? Or is it needed for bcm 90 specifically?
Drives: Polo 6R '13 / Golf MK7.5 '19
Post by ciclo » Sat Aug 03, 2019 2:32 pm
With 86 or 87 is not necessary.
With 90 is mandatory.
Without these new CAN lines for the IC there is no communication with the other units, that is, nothing works.
We have experience from the origin of these modifications. (years)
VASILEIOS1972
Drives: Polo 6R 1.2 tsi , Skoda Fabia 5J Vrs 1.4
Post by VASILEIOS1972 » Sat Aug 03, 2019 2:41 pm
Great presentation and great job, as I understand you are much more than an expert.
Congratulations my friend, here in Greece we are very excited about you and your job.
Best regards and have a great weekend
With respect
Vasileios
exantas
Post by exantas » Sat Aug 03, 2019 2:54 pm
ciclo wrote:With 86 or 87 is not necessary.
Does it have to do with 90 having internal (virtual) gateway and the fact that you stop using the external gateway?
Post by ciclo » Sat Aug 03, 2019 3:04 pm
NO, that only applies to old Bluemotion with external Gateway and also want to install a BCM Max.
Post by ciclo » Sat Aug 03, 2019 3:07 pm
With respect
Vasileios
Thanks. Have a great weekend too.
VASILEIOS1972
Post by VASILEIOS1972 » Sun Aug 04, 2019 9:36 pm
Hello my friend Fernando and have a nice evening , i have some questions
in photo 2 BCM-Fusebox ,
1) SB 58 and SB 57 no needed with new wiring ?
2) SB 36 needed ?
in photo 3b
1) T8/4 (original) pull out this pin , cutting the wire and connect
with T8/7+T8/4 (2in1 single wire)?
in photo 5 Aditional stuff
1) when install straight wires from drls to bcm , how can operate them ?
from max-dot ?
2) with new bcm am i going to have comfort menu in max-dot?
forgive me for the questions but I must be ready when the kit came in Greece.
Best regards
VV
Post by ciclo » Mon Aug 05, 2019 8:07 am
2) SB 36 needed ?
1) NO.
Once the fuse box is removed:
In the Fuse 57 slots there are two wires, one yellow / black and other yellow / green.
- Extract the yellow / black wire with the terminal extraction tool, cut the original terminal, strip and crimp in insulated blue terminal of the new black wire. As indicated in image 2.
Do the same operation for fuse 58 with the yellow wire, as indicated in image 2.
Fuses 57 and 58 are no longer necessary.
2) Mandatory.
Your new Dimmer 1Z0941333 needs a new ground wire, so it is provided by the original green/brown wire with ground signal. Very easy.
from max-dot ?
1) The new light switch and the new BCM Max control the DRLs automatically, you no longer have to worry about DRLs (the button on the fuse box is no longer necessary). DRLs are mandatory, so they should be turned ON whenever necessary (automatically).
2) NO. Maybe it will have another unexpected menu, it depends on whether you are a good guy ... :lol:
Everything indicated in the images is mandatory. Do not make different plans taking personal initiative. Do exactly what is indicated in the images, it is very clearly explained.
If you take any initiative other than what is indicated in the images, your car will not work.
This electrical installation consists of an electronic control of the lights, which needs new cables, the isolation of old cables as indicated in the images (the most important part), and new coding.
VASILEIOS1972
Post by VASILEIOS1972 » Mon Aug 05, 2019 10:18 am
Imageclosest diesel gas station near me
so i pull out pin 4 , cut the terminal and connect with blue connection dual wiring that you made and place pin 4 in T8 and pin 7 in T8 too, am I correct ?
Post by ciclo » Tue Aug 06, 2019 1:11 am
so i pull out pin 4 , cut the terminal and connect with RED connection dual wiring that you made and place pin 4 in T8 and pin 7 in T8 too, am I correct ?
Yes.
Your questions scare me slightly, the installation according to the images is very obvious. :|
An advice:
View the images on a large screen (pc, laptop), do not use the smartphone.
VASILEIOS1972
Post by VASILEIOS1972 » Tue Aug 06, 2019 7:34 am
Yes.
An advice:
Good morning my friend
Don't be scared 😂 I want to be sure
Best regards
Vasileios
Post by ciclo » Tue Aug 06, 2019 9:35 am
Good morning.
Trust what you see to be sure.✅
My main concern is because I don't trust people who ALWAYS use the "quote" button to reply right after to the previous post.🐵... 🤣
Please, use 'post reply' button in such circumstance, thanks. :lol:
Post by ciclo » Fri Aug 09, 2019 11:34 am
Hi Vasileios.
Additional parts requested ready to send (on Monday 12):
+ viewtopic.php?f=41&t=73355&start=45#p559177
BCM
- Factory mode disabled.
- Gateway installation list for your Fabia saved.
- 19 Gateway coded.
- 09 BCM coded for your SK Fabia VRS 2012. BCM Max and Automatic lights, CH/LH.
- MKE loaded and coded. (with ODIS-E)
You'll have to match the remote controls (logically).
Codings already installed:
BCM Max
7A980B3848010000013806B03EEB9BC052C0621F60002041200400020000
Gateway
032204
MKE
viewtopic.php?f=56&t=58703&start=4710#p556790
viewtopic.php?f=56&t=58703&start=4710#p557797
Now I send you a private message so you can contact me by email. :wink:
VASILEIOS1972
Post by VASILEIOS1972 » Tue Aug 20, 2019 7:15 pm
Hello my friend Fernando, one question please for day lights . I took o photograph from T3 connector of day lights . I saw 3 wires . So pin 3 must pull out and isolate and install the new one that you send me correct?
Best regards
VV
Post by ciclo » Tue Aug 20, 2019 8:30 pm
Exactly 👌, grey/black wire in both sides. T3/3.
