Skoda Fabia VRS 2012. Auto lights retrofit OEM
Re: Auto lights retrofit
I act according to the results you tell me.
Try to tell me the results accurately.
This looks like a cricket cage.
- Drives: Polo 6R 1.2 tsi , Skoda Fabia 5J Vrs 1.4
My friend Fernando , final auto scan with no faults , full interior lightning BUT with no dimming interior function
Saturday,31,August,2019,12:04:01:38567
VCDS Version: 19.6.1.0
Data version: 20190529 DS308.0
www.Ross-Tech.com
Dealer/Shop Name: MT SKODA SERVICE
Workshop Code: 231 44700 072242
VIN: TMBEP25XXXXXXXXXX License Plate:
Mileage: 61800km-38400mi Repair Order: bcm max no faults
Chassis Type: 5J-SK25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 37 44 56
VIN: TMBEP25XXXXXXXXXX Mileage: 61800km-38400miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAVE) Labels:. 03C-907-309-V1.clb
Part No SW: 03C 906 027 CE HW: 03C 906 027 CE
Component: 1.4l R4 TSI H15 9971
Revision: L2H15--- Serial number:
Coding: 00250012002400000000
Shop #: WSC 53850 001 1048576
ASAM Dataset: EV_ECM14TSI01103C906027CE 001013
ROD: EV_ECM14TSI01103C906027CE.rod
VCID: 66C3ED1499F16A7F03-8032
Readiness: 0000 0000
Part No SW: 0AM 300 060 A HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6563
Revision: 00043014 Serial number: TFK01108310139
Coding: 0000020
VCID: 285FA32C9B65BC0FF1-807C
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AL HW: 6R0 907 379 AF
Revision: --------
Coding: 410148DB437300B3822712E9C2D200411700
Shop #: WSC 13765 790 00049
VCID: 081FC3ACBFA59C0FD1-805C
Serial number: 25021504650800
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF3A574E161D2BFEB-802A
Address 08: Auto HVAC (J255) Labels: 6Q0-907-044.lbl
Part No SW: 5J0 907 044 C HW: 5J0 907 044 C
Component: Climatronic H08 0103
Revision: K0000000
VCID: 2A5B592445698E1FE7-807E
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 122170091
Coding: 7A980B3848010000013806B03EEB9BC052C0621F60002041200400020000
Shop #: WSC 44700 231 72242
VCID: 2B555C204A9397171C-807E
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 230714 05 54 0403
Coding: 0330AD
Subsystem 2 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3211
Coding: 020000
Subsystem 3 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3211
Coding: 020000
Subsystem 4 - Part No SW: 3T0 959 537 E HW: 3T0 959 537 E
Component: E221__MFL-URO H07 0012
Serial number: 2164426
Coding: 810000
Subsystem 5 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3211
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3211
Coding: 020000
Address 10: Park/Steer Assist (J446) Labels:. 7E0-919-475.clb
Part No SW: 7E0 919 475 S HW: 7N0 919 475
Component: PARKHILFE 8K H06 0210
Revision: -------- Serial number: 28261530202208
Coding: 108101
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_VW75XParkAssis8K 001011
ROD: N/A
VCID: 428B1184D519765FCF-8016
No ASAM data for: "EV_VW75XParkAssis8K" (SK25)
Component: VW10AirbagT20 H09 0020
Revision: -------- Serial number: 003GX00UUUCP
Coding: 003230
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9B39A4ED29AE1F07-801E
Serial number: 3495RRB40590NHDIJH62
Serial number: 3505RRB40590NHDIAOG2
Part No SW: 5J0 920 841 F HW: 5J0 920 841 F
Component: KOMBI H04 0305
Coding: 120C01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
VCID: 2D5152387C87992702-8078
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 032204
VCID: 68DFE32C9BE57C0F31-803C
Component: IMMO H04 0305
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADB99248DE94E1F27-803E
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 5JA 035 193 E HW: 5JA 035 193 E
Component: RNS315-EU H85 0501
Serial number: SKZAZ2R0659899
Coding: 040004110400000000000000
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 3A7B6964BDC93E9F97-806E
Data medium:
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_V11 0073
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11241
Shop #: WSC 13765
VCID: 2F6D4830EA8BEB3730-807A
End-------------------------(Elapsed Time: 02:53)--------------------------
www.Ross-Tech.com
Coding: 0000020
Revision: --------
Coding: 01
Revision: K0000000
Coding: 0330AD
Coding: 020000
Coding: 020000
Coding: 810000
Coding: 020000
Coding: 020000
Coding: 108101
ROD: N/A
Coding: 003230
Coding: 120C01
Revision: B9082001
Coding: 032204
Data medium:
Coding: 11241
Shop #: WSC 13765
Pefect!
I hope your wife enjoys all the new functions of your Fabia.
Why did you buy that dimmer? Did anyone operate this Dimmer on a PQ25?
This dimmer for SK Yeti that you purchased sends signals to the BCM (PQ35), and it acts on the interior lights according to the signals received.
The dimmer for the PQ25 sends the signals directly to the interior lights.
This dimmer was a gift from an O2 pq 35 who install autolights and oem xenons BUT I have this aboveciclo wrote: ↑Sat Aug 31, 2019 10:25 am Pefect!
do you recognise it ?it is from polo 6r red lightning
can we do something with it?
ADL? CORNER LIGHT ACTIVATION? MKE ?
Good morning Fernando and have a good month!
I search enough to find that Fabia mk2 RS do not ever produced with oem xenon .
So I have some questions about the images above
1) ADL, what is new now in my headlights?
2)Corner light activation , my car has in the place of fog lights led daylights .
Is this the problem that I do not have corner light function or need to check the bytes above?
3)MKE activation . I do not have assistant menu in mfd of my instrument cluster .
When i went in adaptation menu and doing test , the procedure do not begin .
See the screenshots above
from a previous thread i saw a skoda cluster none RS model with this function working
aadriver picture
viewtopic.php?f=56&t=58703&start=4710#p557797
if it something with the sw of the cluster the local dealer could not help because the car is not produced any more .
Can any body help me find this file , because i have vcp to upload this upgraded sw.
Best regards
V
aadriver picture
Best regards
V
1st.VASILEIOS1972 wrote: ↑Sat Aug 31, 2019 10:31 am do you recognise it ?it is from polo 6r red lightning
Does 6R Dimmer fit correctly in your SK fabia?
2nd.
Have you checked that the 6R headlights range regulator works correctly for your current headlights?
answersciclo wrote: ↑Sun Sep 01, 2019 9:04 am1st.VASILEIOS1972 wrote: ↑Sat Aug 31, 2019 10:31 am do you recognise it ?it is from polo 6r red lightning
2nd.
1) yes 6r dimmer fit correct in dash oem hole
2) I do not know because Fabia has T8 plug (8 pin) and Polo T6 plug (5-6 pin)
Re: ADL? CORNER LIGHT ACTIVATION? MKE ?
1VASILEIOS1972 wrote: ↑Sun Sep 01, 2019 8:31 am Good morning Fernando and have a good month!
aadriver picture
Best regards
V
Automatic lights, which is different from the CH/LH functions.
You can leave the light switch on AUTO forever until you need to activate the rear fog.
The lights will turn on automatically just when they are needed
2
Your Fabia does not have cornering lights, you need to install the headlights with the cornering function and the module that manages them. (check the Elsawin, ETKA).
3
As I told you by pm, you need to update your IC software for the MKE to work.
DO NOT touch anything on the GW adaptation channels.
I will ask for the IC SW that aadriver has installed in his Fabia. (I think I remember that he is also a user of this forum) memberlist.php?mode=viewprofile&u=26584
I do not know if fabia ever produced with headlights with corner light function but I search and I could not find anything
I have already send aadriver pm for help.
Thank you very much for the details
Best regards
Vasilis
Best regards
Vasilis
T6 connectorVASILEIOS1972 wrote: ↑Sun Sep 01, 2019 9:10 am
JPT https://www.a4-freunde.com/attachment.p ... 1416146148
https://www.a4-freunde.com/showwiki.php ... uebersicht
For your Dimmer tests.
From T8 to T6
T8/1 to T6/4 ... +15
T8/2 to T6/2 ... G
T8/3,4,7 to T6/1 ... ground
T8/5 blue/black wire to T6/5 ... 58d OUT
T8/6 black wire to T6/3 ... 58 IN
T8/8 ... isolate
Keep in mind that everything you do is under your responsibility.
The tests can be done with wires with crocodile clips to return to the original state if you can't get the 6R Dimmer to work.
BCM coding needed.
From T8 to T6
T8/2 to T6/2 ... G
T8/8 ... isolate
BCM coding needed.
Regular Fabia 5j FL elegance trim came with cornering lights on the fog lights. But those are completely different to the vrs models. Different bamper and different lights - one lamp for fog light and one lamp for drl. Drl are on a hw switch next to the fuse panel.2
Hello Fernando , you are the expert, so it is fair for me and for you to prepare a wiring from T8 to T6 connector and fuse box , to make the tests plus new bcm coding.ciclo wrote: ↑Sun Sep 01, 2019 12:25 pm For your Dimmer tests.
From T8 to T6
T8/2 to T6/2 ... G
T8/8 ... isolate
BCM coding needed.
For all those my friend, name the price to continue the project to end with complete success .
Best regards
Vasilis
Thank you very much my friend for the information's , but after bcm max upgrade this hw switch does not exist.exantas wrote: ↑Sun Sep 01, 2019 7:23 pmRegular Fabia 5j FL elegance trim came with cornering lights on the fog lights. But those are completely different to the vrs models. Different bamper and different lights - one lamp for fog light and one lamp for drl. Drl are on a hw switch next to the fuse panel.2
Everything controlled automatic now.
Kind regards
Vasilis
It is possible but:VASILEIOS1972 wrote: ↑Sun Sep 01, 2019 7:51 pmHello Fernando , you are the expert, so it is fair for me and for you to prepare a wiring from T8 to T6 connector and fuse box , to make the tests plus new bcm coding.ciclo wrote: ↑Sun Sep 01, 2019 12:25 pm For your Dimmer tests.
From T8 to T6
T8/2 to T6/2 ... G
T8/8 ... isolate
BCM coding needed.
Best regards
Vasilis
- You have to wait until the last week of September for me to manufacture this adapter wiring for your TESTS (or fully functional if the tests are successful).
- Unfortunately, an original female connector is not manufactured for your current male T8 dimmer connector (ETKA), so we will use a T10 male and female connectors. It involves transferring the wires from the current male T8 dimmer connector to the new male T10 connector (with the same correspondence in the slots to transfer the wires from T8 -> T10). After transfering the wires, the new adapter wiring (T10 <-> T6) will be Plug & Play to do the TESTS.
- The original connectors are not cheap, so I estimate that the final cost with shipping (€ 10) will be between 30 and 40 euros.
I will send you 4 or 5 MQS terminals for you to crimp 2 of them in the blue/black and black wires with the ENGINEER crimper.
Do you agree with the above?
