gear cable secure clips
Bobeek
Drives: MK7
Post by Bobeek » Mon Dec 04, 2017 9:07 pm
hi guys,
I'm trying to find the bits mentioned in the title.. on the pic attached is number 18 ( I know it's not exactly what I need but similar-could be the same)..
my car is a 06 reg 1.4 polo..
Drives: 6R '13
Re: gear cable secure clips
Post by ciclo » Mon Dec 04, 2017 9:19 pm
alexperkins
Site Admin
Drives: 91 Golf GTI, 01 TT 225, 67 Q7
Post by alexperkins » Tue Dec 05, 2017 10:10 am
Can you pop up your reg as theres a chassis break on the gear selectors and the designs are different between them
From a quick scout in etka, your car doesnt have these clips. Its a ball joint selector
Will wait for your reg, then maybe the picture will make more sense.
Bobeek
Drives: MK7
Post by Bobeek » Tue Dec 05, 2017 1:03 pm
GJ06DZF
Why I'm asking is that because few days ago both gear cable jumped off from the pins on the top of the gearbox..called RAC and the guy managed to find some sort of washers to put on that pin so the cables won't fell off but obviously it's just temp solution..
I'll take some photos after work..
alexperkins
Site Admin
Post by alexperkins » Tue Dec 05, 2017 1:25 pm
Photos would be good
heres a pic of the gear selector and cable setup on your car
See if you can identify which number it is
Bobeek
Drives: MK7
Post by Bobeek » Tue Dec 05, 2017 6:28 pm
well, seeing that drawing nothing missing but the gear cables defo jumped off from the pin (where nr 47&50 is)..
see photos below, that washer thing what the rac guy has used to replace whatever was there before..
https://imgur.com/a/ajQsG
alexperkins
Site Admin
Post by alexperkins » Wed Dec 06, 2017 11:48 am
Ok, from a bit of digging, I think you need two of N 908 159 03 -59p each
Bobeek
Drives: MK7
Post by Bobeek » Wed Dec 06, 2017 12:10 pm
Looks like that's the one! Thanks very much!
