Front wiper is not working
Flim
Drives: 2007 1.4 tdi
Post by Flim » Sat Mar 31, 2018 11:16 am
Hi all,
I'm wondering if anybody has had this
Problem.
My front wiper isn't responding to the wiper
Stoke at all. I got it checked out at a garage and the mechanic told me the wiper motor and wiring are
Ok. He assumes there's a problem with the wiper control module or central conveniance unit (whatever that means).
Can anyone shed some light on this? Maybe somebody has had this issue in the past. What should I be paying if it is the problem mentioned above?
Re: Front wiper is not working
Post by RUM4MO » Sat Mar 31, 2018 1:31 pm
I would think that you would need to check the bonnet switch as I think that if the bonnet is not closed, the wipers will not work.
Flim
Post by Flim » Sat Mar 31, 2018 2:28 pm
Thanks, I will take a look into this!
CAMAR
Drives: VW POLO 2010
Post by CAMAR » Tue Jul 23, 2019 11:16 pm
I have same problum front wiper was not working. Rare wiper and washer was working ok. I changed switch and also motor. And also tried lubracting bonet sensor. No use. Can you suggest what to do next?
CAMAR
Post by CAMAR » Thu Jul 25, 2019 12:23 pm
I tried all,with my polo 2010. Mechanic charged 275 pounds without any result. At last told to take to vw dealer to daigonise the fault. Changining wiper motor and switch did not helped. This car does not have mirror sensor. I tried lubricating bonet sensor and also tested by shortening the sensor connector and keeping it open.. Iam not sure this car has any wiper relay. Relay no. 377 which is suppose to be wiper relay, is not fitted in this car.
Can any one help?
LeonSymnz
Drives: 9n3
Post by LeonSymnz » Thu Aug 01, 2019 6:13 pm
Try the fuse?
Post by RUM4MO » Thu Aug 01, 2019 7:21 pm
So maybe the initial issue is a failure of the convenience unit, maybe called the CCM as it is it that supplies the switching voltage to the wiper motor - as the mechanic suspected?
CAMAR
Post by CAMAR » Sat Aug 10, 2019 1:40 pm
In this case I think best way to make it direct annd on 2 speed only insted of going through headache of wiering and bcu problums. Making direct is very easy. That is what i decided to do.
Post by RUM4MO » Sun Aug 11, 2019 10:48 am
So have you rewired the front wipers directly to ignition switched power instead of switching being controlled by the CCM and now everything is working okay?
CAMAR
Post by CAMAR » Tue Aug 20, 2019 2:50 pm
yes it will work ok
Post by RUM4MO » Tue Aug 20, 2019 5:53 pm
yes it will work ok
I'd think that the low current rating of these wiper switches will not take the current that these wiper use for too long.
CAMAR
Post by CAMAR » Fri Aug 30, 2019 5:01 pm
IT IS TRUE IF WE GIVE POWER WIPER DIRECTLY FROM WIPER SWITCH. THEN SWITCH WILL NOT LAST FOR LONG DUE TO LOW CURRENT RATING OF THE SWITCH. BEST WAY IS TO TAKE SUPPLY FROM FUSE BOX AND UES JUMPER FOR SAME FUSE OF WIPER FUSE WHICH IS 20A. AND USE 2 WAY SWITCH SAPERATELY TO START THE WIPER.
