how to get access to the fuse box?
hi all going to hopefully fit the remote cl at the weekend, i need to get accesss to behind the fuse box any ideas?
Open the riverside door then look at the visible edge of the dashboard that would normally be cover with the door.
You should be able to see a cover that can be removed. Just lever it open with a screw driver. It's pretty tight if I remember.
This info Is also available in your vw manual with diagrams.
- MODDED9N
- Location: Newbury, Berkshire Phone Number- 07949 330413
Re: how to get access to the fuse box?
You can see it but reaching it is a whole other matter. Good luck.
yea i know where it is, looks like i need to get access to the back of it
- MODDED9N
Trying to get through to the back of it requires taking out the wipers, the sill on which the wiper is mounted, etc. Both as hard as each other!
Sorry, totally miss read your post, thought you didn't know where the fuse box was. Doh!rasA4 wrote:yea i know where it is, looks like i need to get access to the back of it
thanks for the pic wondering how i can access the rear of it, might have a change of plan anyway so may not need to bother with that now,
Anyone know which fuse is for the tail light? Looked at the manual and it lists all except the tail light. Maybe it shares a fuse?
Rear right tail light doesn't work however the left one does. bulb is not blown either. Brake lights work though.
Also, is the tail light bulb is gone, what's the bulb replacement? Anyone running a LED replacement?
- blazeguarder
You've probably sorted it by now, but you can get to the back of the fusebox by dropping the CCM and relay plate out of the way under the dash, and pushing the fuse box (after unbolting it) out through the gap. You need to bend the plastic frame that the CCM clips to but it shouldn't break if you're careful. Then you can remove the rear cover of the fuse box to access the wiring.
Is it both of the tail light bulbs on the right hand side? There are two bulbs - the top is a twin filament one that does tail/brake, and the bottom is tail only.pog wrote:Anyone know which fuse is for the tail light? Looked at the manual and it lists all except the tail light. Maybe it shares a fuse?
Nope, the rear right Parker light is out. Brake lights still work. But also the front right Parker light is out.
So I'm assuming there is a fuse that controls both the rear and front Parker lights.
Always check bulbs first, the double filaments can pop one only
Can someone just confirm whether the front right parker light and rear right parker light work with one fuse?
The reason I keep asking is because the bulbs aren't blown on either. Funny thing is, front left side parker and rear left side parker works.
So that's why I think the fuse has gone and that they may work in conjuction.
e.g Left front and rear parkers = 1 fuse. Right front and rear parkers = 1 fuse.
Anyway, the car is going in for servicing this Friday but I just wanted to hear it from you guys first.. I . ..just... need... validation.. closure... lol
sorry for large pics
Thanks for that.
Hmm, still not sure which one would be the tail parker light.
I'm thinking it's either (based on the pic): 6, 12, 13, 21, 22, 43 or 54.
Any ideas?
Any ideas?
