Auto lights
rover220
Auto lights
Post by rover220 »
Did any 9n3 come with auto headlights?
I have the light sensor on the windscreen and was wondering if a retrofit could be done by getting the correct switch and some vcds coding?
blazeguarder
Re: Auto lights
Post by blazeguarder »
Is that the light sensor for the dimming mirror only or do you have auto wipers as well? If it's only the mirror then I always thought that it was a sensor built into the mirror only to have it dim properly, as in not connected to the rest of the car?
As a side note, does your car have this hatched area above the mirror? I'm toying with the idea of retro-fitting the auto-dimming one and trying to work out what's required...
rover220
Re: Auto lights
Post by rover220 »
I have auto dim mirror and auto wipers. Mine does have the dotted area yes.
rover220
Re: Auto lights
Post by rover220 »
Do passat/golf/jetty light switches fit the polo size wise?
Gregry254
Re: Auto lights
Post by Gregry254 »
Sorry for the hijack here but, how do you know if you have auto wipers/lights?
The car I am getting next week seems to have all the bells and whistles but the garage didn't mention lights/wipers ... but then again they didn't mention the headlight washers or cruise control either!
candypolo12
Re: Auto lights
Post by candypolo12 »
If you have auto lights the switch for them should have 4 settings instead of the usual 3 and one is called auto for them, wipers you'll have that dotted area on the windscreen and put the wiper switch thing up one and that's them on automatic
rover220
Re: Auto lights
Post by rover220 »
candypolo12 wrote:If you have auto lights the switch for them should have 4 settings instead of the usual 3 and one is called auto for them, wipers you'll have that dotted area on the windscreen and put the wiper switch thing up one and that's them on automatic
Well aware of that.
candypolo12
Re: Auto lights
You maybe yes but I was pointing it out to the person above if you read their comment.
dood9n3
Re: Auto lights
Post by dood9n3 »
