Hi all
Hope you help.
Gti 9n3
Currently using Monza's 205 40 16
Going to lower it soon, only 20mm
Can I use 17 monzas from golf gti ?
Will there be any issues?
Ta muchness.
New member, Alloy/tyre question
Re: New member, Alloy/tyre question
Different PCD I'm afraid, Golf's are 5x112 so no good unless you buy adapters..However, the 6R GTI has 17" alloys, so they will fit fine if you can find a set
Ok thanks,
So as long as its 5*100, it will fit.
No issues with clearance.
Can I go up to 225 or is that too wide ?
Why would you want to widen the tire? I have 195 on the standard rims and mine has 35mm hr springs on and they would fit on mine I am also running spacers
- greypolo9n3
- Drives: white 6r 1.6 tdi rline/gti
It all depends on the offset/width combo of your rim...
Ive had 215/25/17's while my car has been lowered 50mm and there were no issues because the wheels were 41 offset and 7j which means they sat inside the arch
I would like to widen it to get a bit more rubber on the floor. It just wheel spins for fun in 1st and a fair bit in 2nd.
215 25 17 sounds good. Low profile that.
The ones i am thinking of getting are 35 offset.
Would that be enough ??
- greypolo9n3
25 profile is a bit foolish to be honest. You should get 215/40 or 205/40
