1.4TDI Bluemotion engine differences
gernster
Drives: Ibiza mk4
Re: 1.4TDI Bluemotion engine differences
Post by gernster » Wed Aug 30, 2017 8:40 pm
Hi scoody,
Im in the same boat as you, 1.4tdi bms engine with a snapped oil drive chain, engines not siezed but is a bit tight. Id like to fit a new engine but dont have 1200 quid for a bms unit.
If i get an amf engine, and a timing tool and new seal, are you saying, you can get access to fit the sensor buy drilling out the gap in the web in the block?
Id swap the turbo and ancilliaries of course.
Goofy123123
Drives: Polo 1.4TDI bluemotion
Post by Goofy123123 » Tue Mar 20, 2018 7:32 am
Hi just dun the engine swap I put amf In bms but crank wire difront is it any way around it
