Hy everyone, I own a 2008 1.4 petrol automatic polo and my problem is the reverse light. There is no impulse coming from the gearbox to the fusebox. What can be the problem?
Reverse light not working
Re: Reverse light not working
Check if there is continuity on the reverse light switch with reverse gear engaged
Otherwise blown bulb, blown fuse, faulty wiring, faulty switch
Thanks for your reply, bulb it's ok, fuse its nr19 in the fuse box, checked its ok, checked the wires from fusebox to tail lamp all ok but when i have put the tester on the fuse, no electricity impulse is coming to the fuse from gearbox switch.my problem is that its an automatic gearbox, has 3 switches on it and don't know witch one its foulty:( . Waiting for an answer if you know. Thank you!!!alexperkins wrote:Check if there is continuity on the reverse light switch with reverse gear engaged
