Upside down rear wipers
Hi everyone,
So I changed my rear wiper and then moved the wiper manually after to see if the new wiper would touch the windscreen ok (silly I know now!).
After doing so the wiper now wipes upside down in the same motion as it should do on my rear windscreen.
How can I reset this to normal?
I note that when I take the new wipers off, the wiper handle doesn’t turn upside down but in its normal manner.
Help is greatly appreciated!
Sam
Sam
- Drives: 91 Golf GTI, 01 TT 225, 67 Q7
Re: Upside down rear wipers
Are you saying you moved the wiper manually as in rotated it?
Hello, are you still out there?
If you have rotated the stationary wiper arm, it will have moved, ie rotated on its spindle, so if that is what you have done, you will need to sort that out preferably by slackening off the wiper arm securing nut and moving it to the correct position with the wiper off and parked.
