Polo 1.4TDI bluemotion
Goofy123123
Drives: Polo 1.4TDI bluemotion
Post by Goofy123123 »
Hi just put amf 1.4 tdi engine in my 2008 polo 1.4TDI bluemotion but but the crank sencor are difront is any way about it buy cutting the crank wire and connecting the to gether
alexperkins
Site Admin
Re: Polo 1.4TDI bluemotion
Post by alexperkins »
The bluemotion block and the AMF are very different. If using an AMF you should be using a matching ECU and loom so it all matches up
Goofy123123
So it no way to wire the wires together on crankshaft sencor
alexperkins
Site Admin
The sensor is different, you could blow the ECU up doing that.
Goofy123123
Are the key coded to ecu or is plug and play
alexperkins
Site Admin
ECU and clocks
Goofy123123
Hi u would ant no were the vacuum solenoid pipes go on bnm 1.4 tdi plz
alexperkins
Site Admin
What are you wanting to know exactly?
A photo would help if possible
Goofy123123
Change engine and loom ecu clock and key got it started but it hunting and wnt rev at all
