Hello all,
The other day I went to fill up my screenwash, pulled the release and it felt normal, went around to the bonnet and pressed the release as far as it would go and the bonnet just won't lift. Even tried getting my other half to pull the handle while I tried to lift the bonnet and still nothing. Any help is appreciated as I believe I have an oxygen sensor that'll need replacing before my MOT
Bonnet Cable
- Drives: 9N
Re: Bonnet Cable
You don,t want to pull the bonnet up
You want someone to press down on it while you pull the lever as far as you can then try lift the bonnet
See if that releases it
Or try these suggestions
https://uk-polos.net/viewtopic.php?t=25226
