After advice please ,
looking at getting some new headlights for my daughters 9n3 and have seen loads on e,bay for £99 a pair new but not sure what quality will be like ??
anyone had any
headlight advice please
- Drives: 2005 9n3 1.4 16v
Re: headlight advice please
If the headlights have gone opaque - they can be polished up (if that is why they need changing) with loads of 'how to'guides online and on youtube,otherwise I am afraid I have not bought any recently.
Also, if it is just opaque lenses that you can easily sort out as said above, replace the bulbs with Philips Ultras or Osram Nightbreakers to improve the light output.
thanks for replys, do you know what number the bulbs are please
Can you not remove one to check? Different trim levels might mean different bulb types, ie either a single dual filament H4 or separate H7 for dip beam and main beam.
