Please help with this eBay central locking diagram
Orel
Drives: 9n3
Post by Orel »
Helllo everyone,
I just bought this eBay central looking system and got trouble with the installation.
I connected the 12 V, ground, locking and unlocking signals.
The car gets locked but it’s not unlocking
How I need to connect the unlocking.
Thankss and hope you understand [emoji23]
Oh, and where I need to connect the wire of the windows raise
Orel
Drives: 9n3
Re: Please help with this eBay central locking diagram
Post by Orel »
Orel wrote:Helllo everyone,
Orel
Drives: 9n3
Post by Orel »
alexperkins wrote:viewtopic.php?f=10&t=47102
Thank you for this instruction but I’m installed and wired everything. Do you have any clue where Is the unlocking wire? I’m close to finish it and it will be bummer if will need to wait and star over
Thanks Appreciate you work
You can normally pick the wire up from the loom going near the bonnet pull that runs down along the drivers side footwell
Orel
Drives: 9n3
Post by Orel »
I connect the unlocking pulse to every wire of the locking mechanism (in this diagram) and nothing happens.
With the resistor as detailed?
Orel
Drives: 9n3
Post by Orel »
No, where I need to connect it?
180 ohm resistor on the open wire in line with the blue/white wire you have already connected the lock wire to
See the last two pages
http://f.shortnd.it/ukp/vw_polo.pdf
Orel
Drives: 9n3
Post by Orel »
alexperkins wrote:180 ohm resistor on the open wire in line with the blue/white wire you have already connected the lock wire to
Thanks a lottt will try that.
One last question, I ordered the rcn210 stereo. I need adapter for the antenna wire. Do you know which one I need?Image
That looks like an adapter already. Follow the wire back to the loom and see if it’s plugged into something
A photo of the back of the RCN210 will help also
Orel
Drives: 9n3
Post by Orel »
alexperkins wrote:That looks like an adapter already. Follow the wire back to the loom and see if it’s plugged into something
Orel
Drives: 9n3
Post by Orel »
You saw the photos?
Depending on the wiring you have now as i couldnt be entirely sure as it still looks like you have an adapter connected, itll either be an ISO to FAKRA or a dual FAKRA to single FAKRA connection. Both available on ebay
Orel
Drives: 9n3
Post by Orel »
Do you think this one will fit?
