Polo Problems
Polo Problems
I have a few problems on my 1.4 tdi polo, first is when doing a cold start it has a really rough start, when starting when it’s warm it is less rough but still quite rough. I have read it could be sensors, not enough fuel supplied, glow plug. I have checked for error codes and I had a camshaft sensor error but cleared it and it has not popped up since. Also when breaking gently it grips then let’s go and then grips and then let’s go, the break pedal bounces when that happens as well, also how do I fix the rear window heating. Only 3 heating lines work.
